I've been taking a sabbatical from the transmitting side of radio and just can't see myself setting it back up. Radio, atu and PSU have been boxed up and stored properly because I thought I would go back to it. Because I'm out of touch on what any things worth at the moment I was hoping for a bit of a guide as to what to sell them for,particularly as the radio has a fault.
Its a Trio TS120 and the problem it has is that the lower section of 10m (10 - 10.5) doesn't work, I think its the band switch but my eyes ain't so good and hands not so steady, so I'm not going blundering in. Other than that its fine, standard fist mike, full 100w,rarely been used at full power as I have been into QRP since I started.
There's a MFJ 941 versa tuner and a 30 amp/5 - 15 v PSU.
I'm really not looking for advice on diagnosis, I've been through all sorts of checks,including using the service manual to check for correct voltages. I just need some guideline as to what I should ask for it.
Any advice gratefully received. Thanks for looking.
Advice wanted on radio price
- M0JSW
- Tigersaw
- Call Sign: GW6RRL
Re: Advice wanted on radio price
Put it on ebay and get the best price less the high fees, put it on HRD and get offered SFA.
- MrWeetabix
- Admin
- Call Sign: 26TM175
Easiest way to gauge pricing is to search of the kit on ebay, then look at completed listings.... that should give a good idea of the going price.
Then list them on here for 10% cheaper as we don;t charge fees. Job Done
