President Lincoln 2 V3, or is it?
Gaz W
Post by Gaz W » 02 Jan 2019, 10:23
Hi , I have just aquired a President Lincoln 2 V3 ...or I was told it is a V3, it did not come with a box , so how can I tell if it really is a V3 ?
26-TM-652
108EH002
Re: President Lincoln 2 V3, or is it?
Post by 108EH002 » 03 Jan 2019, 09:19
Does the radio have a serial number on the back,if it does.........google it with Lincoln2 CB serial numbers ;)
Many freebanders know otherwise = test free.
27.555 Usb
ballo
Call Sign: 19DD03
Post by ballo » 06 Feb 2019, 20:34
The v3 is the Lincoln 2 and the Lincoln 2+ is the v4 , you can see it on the front.
Lincoln 2 v3 : https://www.communicationworld.nl/presi ... oln-2.html
Lincoln 2+ v4 : https://www.truckerswereld.nl/president ... n-ii-plus/
http://www.pa3hgt.nl
President Veep 40 ch am/fm , President Jackson Classic 6 bander ,Larry International 3 (improved jumbo 3 without rbeep) , President Lincoln 2+, RM HLA 300V+ met Sirio Turbo 5000.
108EH002
Post by 108EH002 » 10 Feb 2019, 20:31
^^The version 3 didn't have V3 on the front of the radio Ballo just Lincoln 11,he also never got the cardboard box it was sold in which had V3 on the box = if you want to be sure Gaz W........open up the radio and check the main pcb code ^^
27.555 Usb
