Albrecht ae-6110 power output ???
- WARLOCK
- Call Sign: 26TM134
has anyone got one of the very small Albrecht ae-6110 if so can you please tell me how you rate it and i understand the output power is adjustable what are the lower and higher settings .
Re: Albrecht ae-6110 power output ???
hi once you mod the radio power output is 4 watt low to 8 watt high on fm with a power outpu of around 10 watts swing on am on high power .Be warned on high power radio will get very very hot
- delboyonline
Cracking little radio, mine does just under 4w.
Don't mod it for 8 watts as it will get very hot. Better to run it into a burner if you want more power.
