https://youtu.be/Hc7eMmFXu9s
Back in 2012.
If you want to see an interesting antenna set-up, search for "sha-sha & blue gill AC Sky"
It is a hobby, some guys like to put superchargers on cars to go fast.They will spend lots of money just to make a few more horsepower.
These guys spend lots of money to see who has the most powerful setup, amps+antenna gain.
73
Jeff
Using a 1.6kW amp mobile
- AShockwav
- Call Sign: KE6LYU
- Gw0wvl
- Call Sign: Gw0wvl
Re: Using a 1.6kW amp mobile
Ah .... The glow of a pair of 3-500-ZG valves .... Lovely
http://s925.photobucket.com/user/madmar ... ort=1&o=51
"It's not the class of license that the Amateur holds but the class of Amateur that holds the license"
My Youtube channel.. https://www.youtube.com/channel/UCp2TU- ... zxPWrLowNA
Dave, did you used to do a run up from Brighton into London on the 23? I'm sure we worked a few times around 82-83 when I was down in Brighton as I've got a sketchy memory of wondering how the hell I could hear someone mobile on Purley Way.
- ghost123uk
- Call Sign: 26TM953
Thanks for the additional input 148
Interesting reading and interesting links
- Unit 148 Mobile
- Call Sign: G4ZOW
Hi Grafter,
Not sure if you're talking about me.
I did not have a regular run on the 23 but did do the London to Brighton run from time to time.
I had a problem in as much as I knew stations could hear me but they were just too down in the weeds and even when I parked up still struggled to make them out of the noise. For this reason I designed my station primarily for shooting skip, It was interesting when I hooked up with similar high power and or high gain antenna system stations as that enabled contact over some really good distances even under completely flat conditions especially at night.
I ran the mobile many nights from either Ally Pally in N. London or Dunstable Downs, sometimes staying out all night, like one did back then.
There was a fella I seem to remember that ran a 4-element yagi vertically polarised from Norfolk with power. He was typically S7-9 into N. London at night on 23.635 LSB and another chap who was the groundsman at Kings Norton golf club in Alvechurch, Worcs. He ran 1kW into a Ham International Big Mac antenna. After visiting him one day I drove all the way back home to Wood Green in N. London without once losing contact.
That is the difference between 4W on a biscuit tin and the mobile station I ran at the time.
I'm considering putting together a beacon on 11m from here in Cyprus where I now live. It would assist anyone knowing that conditions were open to the Eastern Mediterranean and Middle East.
148
148
- Call Sign: Dava
You have to love the lunacy and technical skill involved in running that mental amount of power
