alinco 135 uk
- Call Sign: BPO6O
alinco 135 uk
Any one copied a soft wear for alnico 135 or cant it be done
- andymuza
Re: alinco 135 uk
What Software do you mean? If you mean the programming software then why would anyone want to copy it when it's a free download?
Or am I getting the wrong end of the twig?
- Call Sign: BPO6O
Re: alinco 135 uk
Been looking for free down load files so to put uk 40 on as 1 to 40 but not found any
- Call Sign: M3CBY
Re: alinco 135 uk
If you mean a Data file to write to the radio you can download mine from here https://1drv.ms/u/s!AiFwsALeEFbbivkSoq6IENsH-UEtcw
UK on band a then super low to super high on the others with some 10m stuff on the F band channels 40 to 60
- ghost123uk
- Call Sign: 26TM953
Re: alinco 135 uk
Does the Alinco 135 use the same data files as the Anytone AT-6666 (etc) ?
If it does, I have a well tweaked one (with the UK40 included of course) that you can have a copy of.
EDIT = looking at the pictures of the Alinco, I'm guessing it doesn't use the same files
- WARLOCK
- Call Sign: 26TM134
Re: alinco 135 uk
Do you think your data files would be ok to use with my SS6900n V6 radio as i have been told this is the same radio as the AT6666 If so i would be very pleased to have a copy of them ,Still think you should have bought a magnum . ha ha
- ghost123uk
Re: alinco 135 uk
Warlock, to keep this thread on topic, please look at my TM1 post HERE where you will find a link at the bottom of that posting, and the details of what is within the DAT file. EDIT = please see post below this one.
- Call Sign: M3CBY
Re: alinco 135 uk
The SS6900N isnt the same as an AT-6666 its the same as the AT-5555.
- Call Sign: BPO6O
Re: alinco 135 uk
Hi chaps thanks for all the info got it sorted now
