Has anyone ever used a centre loaded modulator for static mobile? Would be interested to see if anyone has done any comparisons.
Centre loaded modulator
- slamjam
- Call Sign: 26DT871
26DT871 - Ipswich UK
- Mudslinger
Re: Centre loaded modulator
I have had one, to be honest I couldn't tell any performance difference between it and the base loaded version.
They do look impressive though.
- andrew013
- Call Sign: 26AT013
i have all 3 modulators and use only 2 of them and the centre load modulator 2 aint one of them
- Mudslinger
Which 3 do you have Andrew? I have only ever seen the original and the 2, but was led to believe there were at least 3 more.
- andrew013
i have the original modulator , and the centreload mod 2 and the twin coil mod 3 the original modulator new version is slightly different where the whip goes in to the coil as in, its the same coil as the copy modulators (its a nerd thing lol)
- Mudslinger
They also did a black widow which was centre loaded but had a very long coil.
They did a Modulator 2000 base load as well, and a couple of smaller antennae called the Thunderbolt.
I have a Original, but it is a newer original with a shorter coil than the first ones.
- slamjam
ok thanks for the replies - saw the centre loaded on ebay and its one ive never tried.
- andrew013
orignal modulator,modulator super 2, black-widow ,modulator big twin ,modulator t bolt, super t bolt ,t bolt colinear and modultor2000 is the full mobile range ( and the new original version)Mudslinger wrote:They also did a black widow which was centre loaded but had a very long coil.
