arriva buses kent and medway
Scanning radio frequencies for the South East
phillmobile
Re: arriva buses kent and medway
Post by phillmobile » 17 Sep 2016, 14:54
I hear this company has shut down is that right
morgan306
Post by morgan306 » 12 Dec 2016, 10:38
I think I found this yesterday. 166.340. Picking it up quite well in Manston.
trainspotter375
Post by trainspotter375 » 04 Feb 2017, 09:17
Hi All, thanks everyone for your help, yes i found it at 166.525 using sdr sharp with dsd+232 and a cheap R820T from Amazon
trainspotter375
Post by trainspotter375 » 10 Feb 2017, 08:00
hi all, could that frequency be a national one for arriva? only i hear group calls for the wirral and liverpool area, not just kent and medway
phillmobile
Post by phillmobile » 11 Feb 2017, 14:46
Maybe they just have it setup wrong. i would listen but its too weak to pick up here.
trainspotter375
Post by trainspotter375 » 16 May 2017, 08:23
166.3375 nxdn, seems to cover southend and merseyside with other areas in between
2E0LGZ
Call Sign: 2E0LGZ
Post by 2E0LGZ » 22 May 2017, 09:46
When they were installing the base set at our depot in Laird st on the wirral i asked the guy what the frequency was and he said it was 167 MHZ but wouldnt give the actual frequency and yes its the kenwood nexedge network
Uniden Bearcat UBCD3600XLT
Realistic pro 2006 (classic scanner)
Yaesu FTM-100
Yaesu FT-2D
Yaesu FTM-400
Yaesu HRI-200
Icom IC-706MKII G
Motorola SL4000
Motorola DM 4600
Motorola DP 3400
MB6IGZ C4FM Gateway on 434.050 MHZ
trainspotter375
Post by trainspotter375 » 22 May 2017, 09:58
Hi, yes as u no doubt aware nxdn all digital only capable listening on a new digital scanner or a cheap sdr dongle with some free software from internet, as well as 166.3375 im picking up liverpool, birkenhead areas on 166.54375,165.8375, and speke depot on 165.83125
2E0LGZ
Call Sign: 2E0LGZ
Post by 2E0LGZ » 22 May 2017, 10:04
Yep i'm eagerly awaiting the nexedge update from uniden.....if ever !
Yaesu FTM-100
Yaesu FT-2D
Yaesu FTM-400
Yaesu HRI-200
Icom IC-706MKII G
Motorola SL4000
Motorola DM 4600
Motorola DP 3400
Metradio
Call Sign: G7HID
Post by Metradio » 22 May 2017, 12:20
You might have a long wait, only AOR and Whistler have NXDN at the moment..
Mike
