If I get say SDR play and suitable software how easy would it be for me to listen into the local shop watch channel in dunfermline ? appreciate I am relying on the freq being non encrypted - anyone aware if this is the case !
if I choose to go down the route off getting one off the cheap digital dual band handie / scanners available via ebay how easy would it be to listen in without knowing the relevant code etc ?
not sure if to go the sdr route or digital scanner dual bander ?
local shop watch freq listening ?
- gmham
- Call Sign: 108TM154
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Kenwood TS711e
Anytone D578UV Pro+
Re: local shop watch freq listening ?
What frequency do they use? I have Kingsgate centre MOTOTRBO on 453.5000
Whistler TRX-1
- gmham
That's the very one thanks !! got all the relevant info and is it unscrambled ?! I take it the likes off the retevis rt3 etc would allow me to listen into this ?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
Yes it is unencrypted so you can listen in. Not sure about that radio as i use a DP3600.
Whistler TRX-1
- gmham
okay cheers that's good to know. will get hold off a suitable radio and get the info off you if you don't mind.
you got anything else off interest for the fife side either VHF or UHF digital ?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- gmham
PM sent mate looking for relevant codes required for the kingsgate centre.elliotg wrote:What frequency do they use? I have Kingsgate centre MOTOTRBO on 453.5000
thanks.
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
