Grand National 2015 is approaching tomorrow,
National Radio Bank is the supplier and it will more than likely be a MotoTRBO capacity plus system as supplied in the past. The simplex frequencies will likely be separate from the system, but probably still MotoTRBO digital.
The license number is 1029764, using the following frequencies.
- TX: 440.2375 MHz RX: 425.7375 MHz
TX: 440.0750 MHz RX: 425.5750 MHz
TX: 440.2125 MHz RX: 425.7125 MHz
TX: 440.1250 MHz RX: 425.6250 MHz
TX: 440.1875 MHz RX: 425.6875 MHz
TX: 440.0375 MHz RX: 425.5375 MHz
TX: 446.3000 MHz Simplex
TX: 446.2500 MHz Simplex
