Manchester UHF 470-520Mhz
- AshtonMobileScanner
- Call Sign: 26TM931
Is there anything in the 470-520Mhz area for the Manchester area?
Motorola UHF DP3600,
Golden One 1907,
Baofeng UV5RA+,
Diamond RH771 Antenna,
UHF Stubby Antenna,
Diamond X-30 Antenna,
MASS SPS 250 MK2.
(Monitor All Channels)
- Monsta
Re: Manchester UHF 470-520Mhz
Nada..sadly
as you know you get some users (most interesting is security guards and shopwatch) up to sometimes 480
but a lot of them now seem to be using sets which are undetectable/undecipherable
...or perhaps they are ..i can't be bothered these days feeding it from the discriminator to a sound-card and ar$ing about just to read several lines of gobbledygook and in the middle see "sink blocked" ...or some other inane tripe
after that there is nothing really
Its a circle isnt it ...I mean the good old days were brilliant! ..but now the cheaper that Tetra/Airwave and stuff like it gets...the more move over to it, the more that move over the less people want scanners and the less people that want scanners ...the cheaper they get ! ...i picked up a buff desktop that was like NEW for £70 ...less than half price ....Because they guy that bought it couldn't find owt to listen too
now i use it to scan around on the repeaters and not much else
i suppose if i were into planes i would still find use for scanners ....
10/11: Anytone AT-5555, President Lincoln - Astatic Audio
HF: Kenwood TS2000 ,Kenwood G707, Heil Goldline,
- Minus1
Apart from the obvious (digital TV), very little.
You might be able to hear some PMSE transmissions if you are close to a film or TV production:
See http://www.jfmg.co.uk/pages/equip/Talkback/21.htm
and http://www.jfmg.co.uk/pages/equip/Talkback/Inband.htm
You'd need to search those TV channels where there is no TV transmission in your area.
